It is currently Tue Jul 01, 2025 11:22 pm
 Post subject: Floyd Rose installation
PostPosted: Wed Feb 25, 2009 10:43 pm
Hello all,
Any one here have any experience installing a Floyd from scratch? If so I have a few questions for you.
1. What is your procedrue...I know broad question here but it is a start.
2. Which routing templates do you use if any....Stewmac, homemade...etc
3. I want to install a recessed one. I know the Floyd site has deminsions that you need to follow. But with those how deep does the neck pocket need to be for good action?
4. If recessed do I need a neck angle?
I probably have more but this is a start..... Eat Drink
Thanks for any info.
Matthew
PostPosted: Wed Feb 25, 2009 11:01 pm
Last Name: Shaw
City: Philadelphia
I havent installed one in years since i did one on my personal guitar years ago. I used the stew mac templates and neck shelf jig. I was very successful for a first try. I'll admit though another method might be better for the neck shelf since the jig relied on a dremel tool and I felt the dremel tool was under powered for this job. just my opinon. i have never been a big dremel fan. I have no tips to offer since i havent done one in years except make sure your measurements are exact. If off just a little you'll have intonation problems. Like I mentioned the ready made stew mac jigs were a big help. The purpose of the recess around the floyd is not reallt to lower the floyd it is to allow room for reverse action in pulling the bar up away from the body like steve vai does alot. You should not really need to angle the neck pocket at all. Though you may need to use shims to get thing perfect if your install is not. Good luck...Mike
PostPosted: Sat Feb 28, 2009 6:15 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I used a homemade template... get the measurement from http://www.floydrose.com/instructions.html and trace the lines onto a piece of 1/2" (or thicker) plywood. Cut the hole out with a jig saw (band saw won't do in this case...) and finish with files. Take the unit and compare it make sure it's right and file it until it fits. If you are not planning to make them recessed then the template is optional just drill the holes for the stud and insert them and shim the neck pocket for the angle needed, if it's set neck or neck through you have to recess them. I am doing this on a finished guitar (it was a retrofit from wilkinson) so cover the entire lower bout with blue masking tape, then mark for your mounting holes and drill them on a drill press. Make sure you err on the tail side when drilling holes so the unit doesn't come too far towards the neck and interfere with the pickguard or whatever (it will come forward a bit due to string pull anyways) and position the unit over the hole (if you can insert then remove the stud insert it to get an accurate representation of the unit) and position the template over the unit and when satisfied mark the position (or mark where the unit is and place template over that). You may affix the template with clamps but I used double stick tape making sure it does NOT move at all. Use a 1/2"x 1/2" template bit route the front ledge about 1/4" deep or about 6.35mm (this is from the measurement on the floyd rose website), the back ledge should be almost 1/2" or 11mm or so. Doesn't need to be dead accurate anyways. After that remove the template (I had to reposition the stud holes several times... be sure to err on the tail side), insert the stud and install.
If you do not have the required tools (laminate trimmer, drill press, appropriate bits, and templates) then either get the tools (you will use them for other guitar builds anyways) or have someone competent do this. If this is a particularly expensive/irreplaceable guitar then definitely get a competent professional to do this. If it's a vintage strat or whatever sell the guitar then make a new build... you will devalue your guitar if you do this! You may buy the template if you feel up to it or make it yourself... I did because NT to dollar exchange sucks and I am trying to import as little as possible.
For the nut end I actually used chisel and files for it because I don't know how to jig a router for this operation and a slip means an unplayable neck. You get better control with hand tools but it isn't going to look as good. I have seen people build boxes or whatever and jig their template bit over that but for me it was too risky. Anyways once you get the ledge made by whatever means, checking depth as you go (if you go too deep it's fine, you can shim it) You will use the appropriate nut and line it up good and drill the holes (they are all different do not drill anything until you have all the parts in your hands!) and the back counterbore if necessary. You will need a drill press for this operation.
Typhoon Guitars
